For full features; Go to At wits end!!!!!!!!!!
I have a 92' Buick Regal 3.1L went out to start it sunday and wouldnt not
start, its cranking and trying but just wont... but we didnt hear the fuel
pump come come. so we just replace the fuel pump,filter/strainer, n relay
and still same.. and prior to this we had installed 3 new coils,3 of the 6
spark plugs and wires, and new battery... so just went and got a harmonic
balancer to put in a new crankshaft sensor today. if anyone has any idea's
on what could be the problem tht be gr8.. just not getting gas for sum
reason smell nothin coming out the tail pipe, plus cnt hear the new pump
turning on.. thanks:doh:
Rizzo420
we decided to not do the crankshaft sensor because the injectors are
getting power, theres spark and we think we hear the new fuel pump turning
on, but not sure and still not starting...my bro who teaches at linc tech
said might be wiring/connection to the fuel pump..ne help or ideas would be
gr8 guys...
Rizzo420
Tried dropping a tablespoon of fuel into the plenum to see if it kicks?
Wally
well were gnna head back out there today and re drop the tank again, and
check all the wires and hoses maybe we gotta wiggle sumthin, cause fuel
pump is not gettin power.. and everything else is working, theres spark,
injectors r good, coil/manifold good.crankshaft sensor good, (thts why we
decided not to change it yest cause it wouldve been waste of time).. so if
this doesnt work then just gnna have to have it towed in cause were at a
loss now...
Rizzo420
yea the penlum is all good.. it has spark and compression, injectors all
good... just no pwer to new fuel pump, so were ogin to get an electrical
test light right now to see maybe the sending unit or the wiring or
wht....if guys have ne ideas pls share..
Rizzo420
Here the things I'd check first:
Fuse
FP relay
and connections
Some cars have a fuel pump test wire that allows you to by pass all fuses,
relays and computers, it sends power directly to the pump.
corbett_auto
