car forums
Driver's door very hard to open?
For full features; Go to Driver's door very hard to open?
:ticking: Have 93 Cutlass Supreme, driver door very hard to open. Handle feels too easy to move. Got door panel removed, was going to pull inside door mechanism but it does'nt look like I will be able to hook up the links to outer door handle. was going to bend rod for outer handle? but not any room to get at it! really need help, my truck just started leaking A/F. need help so wife can drive her car. posted by  wsowles
You shouldn't have to bend anything, unless something is broke. Why can you not hook up the linkage? posted by  corbett_auto
There is no room to get my big paw in there. Unable to reach w/pliers, no openings big enough and if I take the "door handle" assy. off inside the link would probably come off. In that case, how will I be able to put it back on?
Any and all help is gratefully appreciated!:thumbs: posted by  wsowles
In cases like this we occasionally cut a bigger opening. Would this help? posted by  corbett_auto
Is it a 2-door? Does the door sag when you open it? Could just be the door rubbing on the rockers. If so, it's just hinges...unless the holes are egged.
Simple>difficult posted by  Satty101
Cut hole in door. Able to get in side w/door assy. attached. Works fine. installed new link.:thumbs: posted by  wsowles
Slogan T-shirts from $15
itself Slogan T-shirts
SELL YOUR CAR
@ CF Classifieds
