For full features; Go to 1993 Jeep Grand Cherokee
I have a 1993 jeep grand cherokee limited which is rolling over, but will
not stay running. As soon as it starts it dies and if you try to give it
gas it dies also. It was not doing anything and the solinoid on starter
was cracked, I changed the starter and it now rolls over as I stated above,
but continues to die. The fuel lines have flow and pressure and the pump
also kicks on. There is no sign of the relays being bad; although they
could be and how do I know? There is spark at the spark plugs, as I
checked that too. Even though there is flow in the fuel lines, could it
still be a pump? Is it worth saying that I also tried to start it while in
neutral and still same as above.
05jen09
check trouble codes
tbaxleyjr
