only half of the factory radio will light up
Home  \  Repairs & Maintenance  \  only half of the factory radio will light up
hey my friend asked me to check this out and it left me stumped and i was wondering if you could help. the vehicle is a 98 chevy blazer LS , V6, there has been no previous wiring work to the vehicle.
the problem is that when driving at night only half of the radio will light up (radio is factory) i have tried checking fuses and all of the fuses are intact.
Any suggestions ?
posted by  vette2004
There's usually a single power source to the radio so I'd guess at a bulb, as one light works it won't be a fuse.
posted by  HighWayMan
does it have a face off part? is it the bit that comes off or the other 1/2? is it just the LCD screen?
posted by  cinqyg
Sounds like it needs replacing. Changing out bulbs sometimes tends to be quite expensive. On our last car, a 1991 Lexus LS400...the dash was illuminated in green strips...I'm sure you've all seen it. The radio had the same type of problem. I had it checked out and the labor to change out the bulb was $150.00... cost of the bulb...$1.98. Of course on the Lexus, to replace the headunit would've cost just over $1,000.00 bucks plus labor.
The cost to replace a bulb on a Chevy radio vs. the cost to replace the whole unit is probably pretty close. I'd think about having the whole of it replaced.
I could be wrong...(see my help stat) :laughing:
posted by  BavarianWheels
