Pinpointing and stopping oil leaks?
My '60 Metropolitan has a few oil leaks that start dripping under the
engine after I've been driving around for short while. Does anybody have a
good method of finding and stopping them?
The first thing you must do is figure out exactly where the leak is coming
from. You need to clean the engine off as good as you can, pressure wash if
possible. Then keep a close eye on it until you see the leak. Remember that
the oil will basically flow straight down, so follow the leak up as high as
it is wet. This should be the spot. Most likely it will be a gasket that
needs to be replace.
If all else fails take a few pictures like you did for the distributor.....
I will check on removal tomorrow. Look almost identical to a MGB engine
which is what we are installing in the Custom Morris we are building.
Alright, thanks, I'll start by giving that engine a good scrub-down, it needs it.
