1991 Pontiac Firebird
Home  \  Repairs & Maintenance  \  1991 Pontiac Firebird
I have a 1991 Pontiac Firebird 5.0L V8 Automatic and everytime i put the peddle to the floor, it makes a loud cluck noise, and it feels like it is under the drivers seat area. This only happans going from 1st gear to 2nd gear, i though it might be a U-joint but mabey you guys can tell me what it is.
posted by  dmhjcd
A little bird has told me that it is most likely a broken transmission mount.
Very common problem with that car.
posted by  BavarianWheels
How much does it take to fix that
just wondering if you know
posted by  dmhjcd
With basic hand tools, some jack stands and a floor jack you can swap the mount in about 1/2 hour.
The mount should cost about $20.
Cheap and easy all you need is a new mount a good jack. min of 3 bolts to take out max is 5 depending on exhaust system
posted by  Ga Modified
Thank
posted by  dmhjcd
Thanks you guys, it was a broken transmission mount. The transmission was jumping a good 6 inches. It is fixed and working great.
posted by  dmhjcd
