coolent problems please help
Home  \  Repairs & Maintenance  \  coolent problems please help
my car overheated so i changed the thermostat and it stopped overheating but now the temputure gage on the dash constantly reads in the red so i replaced the cinder unit and its still reading in the red im out of ideas if you can think of something or have any suggestions please help thanks.
posted by  butthead
This will do better here in R&M...
And it might help more if you supplied a detail or two more...
posted by  BavarianWheels
Yes, and an intro...maybe... :ticking:
posted by  Cliffy
Yeah I think I will take up VWHOBO's old job of making sure that when the phrase "DUH" was needed, it was called out.
Hey Butthead (hmm appropriate?!) before you can expect any help with a vehicular problem, you must first understand that most real tech's actually prefer the car to be in their presence rather than online due to the complex nature of diagnosis and troubleshooting. With that now stated and known, I will expand that thought into the fact that when you ARE online explaining a problem expecting help, it is nice to explain any and everything involved in the equation starting off with things like what kind of vehicle we might be talking about like year,make, model, engine type and size, etc.
Now I will expand on what I do know about this problem......, you say that you replaced the thermostat. Other than the overheating, why do you think the thermostat was causing the problem? Did you do a heating system check by running the HVAC system in heater mode and were not getting any heat? The thermostat could most def. cause your problem, but I would never jump to conclusions before making sure that ALL factors point to it. If the thermostat was stuck shut, you'd not have any heat inside and she'd be prone to overheating. If it was stuck open, the engine would not reach optimal operating temp. and you'd still not have "much" heat inside.
Deductive reason process: If you replaced the thermostat and then engine did not everheat and you checked and you were getting plenty of heat from the heater inside, then it would seem you solved the problem with the thermostat. HOWEVER, you say that you also replaced the "cinder" unit because the gauge was reading red. What is that? Cinders come out of my chimney in the winter and from coal- powered locomotives. I guess you replaced the thermostatic coolant temperature sensor aka. "temp sending unit." :hi: When your gauge now shows a temp in the red zone, are you really overheating? Does the car have a strange burning odor or is coolant in the recov. tank boiling? While this is going on does the heater blow hot air?
I fully support, at this time, that when you replaced the thermostat, you have gotten air into the line somewhere and on the side that the temp sensor is on, it is getting hot. All your info. points to this thus far. The second theory that Wally has about having a cracked/damaged head gasket superheating the coolant is not likely in this case! First off, if you had a bad head gasket, gases(compression) and liquids(coolant) typically flow both ways but not all the time. If you are lossing compression to the cooling system due to a bad head gasket, you will typically notice air bubbles in the coolant recov. tank due to air in the system and it is not from boiling. Boiling would be if it was overheating. When the engine was off you'd likely have coolant draining into the engine oil as well. you'd also likely be burning white smoke. All that depends on where the damage would be to the gasket and what I just said does not ALWAYS happen. I think your problem is far more simple than all this.
You need to do a more in-depth diagnosis and tell me answers to the questions that I have posed before I or anyone else can help you any more. You're now saying that it is NOT overheating yet the temp gauge runs in the red all the time. Bleed the system of air....I think you got air in it.
posted by  cmeseadoin
Few other surgestions:
If you havwnt already then descale and gunk your coolant system, as this oftern causes cooling problems, then bleed it of air, there is ussally a vent screw on the input or output of the heater matrix or highest point of the hose system. This will allow you to remove most of the air as this is where it will congregate. Depending on the layout ie integrated coolant bottle or seperate bottle and its position, there will be another vent line on the radiator in the aposing top courner of the hoses. All depnds on the car.
Other cheap simple things to look at are the fan sensor if you have an electric fan, this probibly will be screwed into the side of the radiator or off one of the hoses and will have 2 wires running to it.
posted by  cinqyg
Another way to bleed the system of air is to remove the rad cap, start the car, let it heat up and keep topping up the coolant in the radiator whenever it starts to go down. You'll see the coolant in the filler neck bubbling. This is air escaping. Once it reaches full operating temperature and the thermostat opens, depending on how large the air pocket is, the coolant will likely drop suddenly. Be sure you are paying attention and topping it up. Once the car reaches full operating temperature and no more bubbles are bubbling, you're in the clear.
posted by  KNTRDR
I don't know about american cars, but european, japanese and australian cars have a cabin heater that is fed by water that bypasses the thermostat circuit. So your thermostat could be shut and the cabin nice and toasty.
Thus the thermostat is only there for its intended purpose.
butthead have you checked for a stream of bubbles in the radiator? With the cap off, what does the water level do when you rev the engine?
The cars thermostat (setpoints range from 170 F - 195 F depending on manufacturer) controls the engine temperature only
sorry for the intruted but can anyone tell me where the cooling temp sensor is on a 92 buick sensor 3.3
posted by  sweetkim
well here ya go... :mrgreen:
Coolant temp sensor on a GM 3.3 is on passenger side, in the head. The electrical connector is immediately beneath the alternator.
