1995 Nissan 240SX check engine light
Home  \  Repairs & Maintenance  \  1995 Nissan 240SX check engine light
Hello everyone.
I have 1995 Nissan 240SX with Check Engine light on. The check engine light came on periodically after about 90,000 miles, but now stays on indefinitely. I am told this may be due to a faulty oxygen sensor but not sure after reading the OBD-II Code P1320 from using Actron.
BOD-II P1320 Code - Ignition Control (IC) Module 4x Reference Circuit Intermittent No Pulses or Ignition Signal? What is this mean?
Please help, I need to get this car passed emissions inspection by early June.
posted by  jomjalee
Early June starts in...48 mins...about the length of a basketball game
LAKERS!!
posted by  BavarianWheels
I hit edit instead of relpy Nothing changed in your post
Thanks for your help in advance...
Camshaft sensor or faulty optical distributor most likely. Some Nissan 4 cyls have the camshaft sensor as an integral part of the distributor which means the distributor and camsensor are replaced as a unit Does your 240sx have the KA20DE 4cyl? If so I have other insights to share
