1994 Ford Escort Intermittent Crank/No Start Problem
Home  \  Repairs & Maintenance  \  1994 Ford Escort Intermittent Crank/No Start Problem
I am the original owner of my '94 Ford Escort LX Wagon. It has been my first and only car but needs some help after 205,000 miles.
For the past few years my engine will crank but not start on the first try. This started to happen at 130,000 miles.
This happens frequently in the summer but rarely in the winter. Problem happens in 15% of starts during summer and less than 5% of starts during winter. More likely to happen when engine is warm.
Car normally starts before an accurate diagnosis can be made. Previous error codes have been KOEO 111, KOEC 111, KOER 111.
Diagnosis at Ford service three years ago was possible intermittent EEC power relay concern and possible crank sensor concern.
I list these additional issues with the hope that they are related to my crank/no-start problem:
1) In summer when A/C is on, engine temperature will proceed up to the top of normal section in city driving. It returns to lower part of normal section at high speeds.
2) Acceleration is poor as car gets hotter. Sounds like there is a straining sound as car accelerates in hot weather once engine is warm. Car has never overheated and acceleration/engine performance is normal except during summer.
3) Sometimes A/C and other power components (e.g., wipers, headlights, etc.) do not come on right away after start-up. Most of the time they come on right away, but sometimes car must be driven for a few minutes before they work. This happens infrequently and tends to happen to the A/C more so than the other components.
4) Car has stalled a few times when speeding up quickly and then stopping right away.
5) Engine surges every now and then during acceleration.
Recently replaced:
- Fuel pump
- Water pump
- Timing belt
- Serpentine Belt
- Air valve
- Air sensor (cleaned only)
- A/C compressor clutch, hub, and pulley
- Exhaust flex pipe
Taking these problems together, I'm hoping that a faulty EEC relay could be the culprit. Please advise if this makes sense given the above history or if the problem is probably more complex. Any advice would be appreciated.
1994 Ford Escort LX Wagon
205,000 miles
1.9 Liter/4 cylinder/automatic
posted by  nickrand
111 on an EEC-IV computer system is normal system pass
Assuming you ran Key On, Engine OFF test:
The first code 1 indicates communitation is occuring normally and the computer is in diagnostic mode
11 is a separator pulse
111 means everything in normal range.
Did you run Key On Engine Running Test?
KOER was run and passed.
The fuses and sensors were checked.
Fuel pump was replaced as preventative maintenance.
I've had the fuel injectors cleaned several times.
I'm not much for diagnosing these problems myself, so my goal is to narrow down the problem to an area that someone else can test. I'd love to do it myself but don't have the knowledge or experience.
Could a fauly EEC power relay cause all of my problems?
posted by  nickrand
I have the EEC-IV in my Crown Victoria and know a little about it
Lets look @ what we know
car passed KOEO and KOER tests (indicated by codes 111)
Car's starting issues occcur on cold start in warmer weather
acceleration sluggish with wram engine and hot weather
Car runs much warmer with AC on than with it off
Wally or someone may have said some of this already -
Re-do your KOEO and KOER test and wigle the wiring around all of your sensors and see if you get codes - this will help identify wiring problems in the EEC-IV system
Just for good measure, I would test the coolant temperature and intake temperature sensors. These can be tested with a DIGITAL multimeter and by reading the instructions from a good manual for the car.
http://www1.autozone.com/servlet/UiBroker?ForwardPage=az/cds/en_us/0900823d /80/13/bf/bd/0900823d8013bfbd.jsp
http://www1.autozone.com/servlet/UiBroker?ForwardPage=az/cds/en_us/0900823d /80/15/64/22/0900823d80156422.jsp
provides details on how to accomplish that.
This will rule out bad temperature inputs to the ECM which will cause the car to run lean but have not gotten bad enough yet to throw codes
Next, do what Wally mentioned and check the electrical grounds
Change the fuel filter and do a presure test on the fuel system (confirm values from a shop manual) looking for 30-40 psig engine running @ idle, 40-50 psig with vacume hose disconnected from regulator, engine running , 40-50 psig engine off, key on - we are looking for blocked supply or return lines, bad fuel pump.
If these things dont find the culprit, we will commence digging into the DIS ignition system since bad ignition modules and bad cam/crank sensors cause intermittent issues on warm engines as well. The only easy way to test some of this stuff easily is spend $20 on a new crank or cam sensor and replace it. There are some voltage test to run on your coil packs and ignition module if you want to go this deep.
you need to put cold spark plugs in it
you have to hot of spark plugs now it could burn up your engine
posted by  AutoPro
hell, if it's a ford, just count yourself lucky that it starts at all...:hi: :wink2:
posted by  dodger65
Watch it :wink2:
First On Race Day
posted by  99integra
w/e For Our Retarded Daughter...
i told my wife that one when she had an escort and got slugged...:doh:
F*cking Old Rebuilt Datsun
:laughing: :laughing: :laughing: :laughing:
posted by  dodger65
Nice :laughing:
posted by  99integra
No no no....Ford= Fix Or Repair Daily:smoke:
Besides that, you do realize this thread is older than crap right? :wink2:
posted by  97Talonchik
yeah, that's why we're not answering the question or anything like that...:wink2:
posted by  dodger65
