best way to lower a mazda?
Home  \  Repairs & Maintenance  \  best way to lower a mazda?
what is the fastest and best way to lower my 92 mazda standard cab. i am thinking of drop blocks but the front end i need help understanding how to lower it.
posted by  tylerh
what kind of suspension does it have up front, also how much do you want to lower it?
posted by  RichG
Lower the rear with lowering blocks. The front has longitudinal torsion bars. Follow them toward the rear and at the end you'll see the adjusting bolts. Break loose the lock nut and loosen the bolts equally on both sides (try about two turns to start). Put it back down on the ground and move it to settle the suspension and you'll have a starting point. Adjust from there to reach desired height. Make sure you always adjust them equally.
Well, it's been over a year now. Is it too soon to call you a jerkoff for not saying thanks? Jerkoff! :fu:
