Removing Seats On my Passat
Home  \  Repairs & Maintenance  \  Removing Seats On my Passat
hey guys, i want to install an amp and 2 subs by myself...is it easy to get wires under carpet?? and how do i remove the seats???
posted by  wumember
lift them up unbolt them probibly 13mm (1/2) bolts. should come straight out, the easiest way to get the wires under the carpet is take it out, take the tread plates off the doors and it should come straight up. other thing to bear in mind is that the seats act as sound insulation so you will increase road noise. the wires should be threaded in coundits really for example thought the sills or headlining as they cannot be caught there and dammaged. dammaged wires can lead to electrical fires.
posted by  cinqyg
