Front Left Signal Light Not Working
Home  \  Repairs & Maintenance  \  Front Left Signal Light Not Working
Need help! My front left signal light is not working (not blinking), but the lights are functioning. What can the problem be? At first I thought it was the bulb itself, but heck, the bulb is functioning. It's a 97 pontiac grand am. Please HELP! :ohcrap:
posted by  fyrefyther32
Is it only the left turn signal that doesn't blink? Is the turn signal light *on* when you turn on your headlights? Or do they only turn *on* when you signal a turn? It could be the *blink* part of the light is burned. I don't know the tech term for these bulbs....double-something?
Replace the bulbs anyhow...they're only $5.00 at most for all four.
If the bulb change doesn't change the problem, it could also be a turn signal relay that has gone bad...they go bad after a while.
posted by  BavarianWheels
Does the rear light work ? if a bulb is bad in rear the front won't blink also check your turn signal flasher ,have seen them to work only for one side. good luck Slim :screwy:
posted by  Slimone
