1994 Pontiac Trans Am Won't Park - goes to neutral
Home  \  Repairs & Maintenance  \  1994 Pontiac Trans Am Won't Park - goes to neutral
Hello, I have a '94 Pontiac Trans Am. When I shift to park, the car actually goes into neutral.
Is this something easy to fix :clap:, or do I need to take it in :banghead:
posted by  alchemista
would be nice if u introduced yourself in the introduce section first too.....
anyhow, it seems like such a simple problem, but i honestly dont get it. goes from parking to neutral? the stick? or just the whole car even though its set on parking?
posted by  Inygknok
What happens is that the car will still roll even when in park. If it's on a hill, it will roll backwards even when in park. When on flat surface, you can push the car.
You've either got a shift linkage or transmission issue. Hard to diagnose online. Will need to be checked out by someone in the know. If "park" is "neutral" in your car, is "reverse" actually "drive?" That would tell us if the linkage is off by two drive ranges?? :2cents: :2cents:
posted by  cmeseadoin
