95 explorer radio power button not turning off, need advice.
Home  \  Repairs & Maintenance  \  95 explorer radio power button not turning off, need advice.
i pulled out my stock radio in my 95 ford explorer because the power button is broken, not "turning off." whenever i push it in it just pops back out. i opened the face plate but it seems to be attached to some wiring so i cant pull of the face plate all the way. however i see the mechanism where the power button goes in and out so how can i go about fixing this problem?
if its not fixable, should i buy a new stock radio? i cant find it online. the part number is F57F--18C852--BG.
any help would be great!
thanks!
Sean
posted by  SWhockey98
Sean, most of us on here are mechanically oriented around automotive applications and not electronics. If you can pull the radio out of the truck as you seem to indicate you have, and you can tear it down yourself and see what is going on, then try that. If the problem is a plastic button or something non-electronic you can try and fix it. Otherwise you might try taking it to an electronics company and seeing if it is worth fixing.
One thing you probably will find is that in order to go to ford and get that stock unit, it will be WAY more money than going aftermarket. That is what I found anyways regarding a Jeep system that I have and tried to replace stock. Unless you can find it on ebay or some other way, good luck, you'll probably be best going aftermarket if you need to have it replaced. You could see what it will cost to fix too. Good Luck
posted by  cmeseadoin
thank you!
NP..... Good luck with it. Let us know what you find out!
it turns out i found a service repair shop out in massachusetts that'll do it for $97. i guess it's better than paying $215+ at the ford dealer. :ohcrap:
Yes sir, go for it. Sometimes that is what you have to do! :-)
