1988 ford bronco ll timing chain
Home  \  Repairs & Maintenance  \  1988 ford bronco ll timing chain
i have a 1988 ford bronco ll, and i have a problem with the timing. i rotate my distributer and still can't seem the timing right. is there anything else besides the timing chain that can cause this. :smoke: :mrgreen:
posted by  frogger5000
If you do not have the "spout" connector disconnected, the computer will "correct"(keep the timing where it is) even if you do rotate the distributor. The spout connector should be located near the distributor's ICM. It looks like a little black plug with two wires going to it, to the untrained eye, it would look like a worthless piece of plastic. It would be wise to look it up in a wiring diagram.
posted by  Sick88Tbird
