Poweer Windows
Home  \  Repairs & Maintenance  \  Poweer Windows
MY 94 PA, I believe has a direct short somewhere in the power window circuit. As soon as I turn the key on (Without activating any window) I can feel the circuit breaker heat up. I can use the windows as long as I do it as soon as the key is turned on, I get about 5 sec before the breaker trips.
My question is this, is this vehical prone to any shorts in a particuliar place? So I can begin my long journey to find where it may be. :banghead:
posted by  park avenue
Hi , yes GM has had some problems with the connections at the window motor inside the door ,now I have come across a few that shorted out in the harness where it goes thru the door,Might look there first, good luck Slim :screwy:
posted by  Slimone
I agree. I have had a couple also where the wires would break between the door and the car. It is easy to check those, just pull the rubber back and look inside.
posted by  theman352001
