Electric window will go down but not up
Home  \  Repairs & Maintenance  \  Electric window will go down but not up
We have a 1997 Dodge Intepid. The front passage window will go down but will not go up using the switch on the passager door. It will go up fine using the driver side switch for that window.
Just wanted to ask out there what could be wrong and if this would be something we could fix without having to spend a bundle.
Thanks,
Debbie
posted by  Debbie25
Not knowing the Dodge, it could be as simple as replacing the window switch.
I know very well that BMW's makes these easily changeable just using a finger nail.
posted by  BavarianWheels
Seems to me its probably the switch. If you know anyone who can do this try this. If the switches are the same for each door try taking the switch from the pass side door and put it on the dirvers side and see if it works. If it does theres your problem.
posted by  69396Chevy
I was able to pop off the small panel that held the switch. I was going to just purchase another switch but decided to clean up the toggle connection first.
Well it worked. Problems fixed.
Thanks for all you help,
Debbie
posted by  Debbie25
