1989 Mustang Battery Problem
Home  \  Repairs & Maintenance  \  1989 Mustang Battery Problem
would it possibly be that something was on? i heard that would do it.
posted by  drewster
Hello all, yesterday i had a problem with my car. I got a new battery, and new cables for it, i installed the cables (2/4gauge) and when i went to put the cables on the battery it sparked at me, i tried again holding it down, and it fried a wire, or something nearby. What could be the problem?! how does that happen? thank you all for your help. bye
posted by  drewster
Well assuming there was no problem to begin with, which I have to because you didn't say why you did this work, it would be apparent that you hooked something up incorrectly.
Basically there are two options;
1. You attached both cables to ground (it's almost impossible to hook them both up on a positive terminal). Re-check your connections.
2. You hooked them up to the battery backwards.
It would be somewhat easier to help diagnose the problem knowing what smoked when you hooked them up. Saying "a wire or something nearby" just isn't enough info.
Please try reading my first response!
