Spark Plug Reading
Home  \  Repairs & Maintenance  \  Spark Plug Reading
I checked my spark plugs today and they are white on the ground strap only. Sorta greyish white, not 100% white. I thought a tanish brown is the optimum color for the correct combustion occuring. Is there something specific is the spark plug is a little white? 85 Olds cutlass Ciera 3.8L V6
posted by  speedy266
Sounds like it's running lean. It could also mean that you're using plugs that are too hot: it may need cooler plugs.
It's probably best to check with an exhaust gas analyser, though: plug reading is apparently upset slightly by some of the modern fuel additives, but it's something I still use!
posted by  heebee
i justfound out i was given spark plugs for the 86-88 3.8L. My 85 3.8L has iron heads. 86-88 has aluminum heads. I compared both spark plugs side by side and the one recommended for my engine has a reach(threaded portion) half the size of the ones i was given. Theres no mechanical damage to the spark plugs of the piston hitting it. Would that cause the temps to rise at idle?
posted by  speedy266
