Too much injector cleanner?
Home  \  Repairs & Maintenance  \  Too much injector cleanner?
Hello,
This is my situation: I've added too much fuel injector cleaner (double dosage) into my petrol and are experiencing the following problems:
- Car will not start properly without a good revving
- After over-revving the car after 5 mins performance is close to normal
- During those 5 mins thick smoke is produced, then disappears
- during those 5 mins, engine sounds like it's choking.
Should I take it to the mechanics or run out the petrol?
Any help is appreciated :)
posted by  DavidRoddy
Keep running the old fuel out and as you do fill up often so dilute it as much as you can. I dont think it would have caused any harm to any of your components. Which Injector cleaner did you use?? Id only reccommend "Lucas Fuel Injector Cleaner & Upper Cylinder Lubricant" You cant overdose on that stuff. Works really good! And 1 quart of it can treat 100Gallons.
http://www.autobarn.net/luc10003.html
posted by  speedy266
