Can't peacefully remove the turn signal cover on my Buick
Home  \  Repairs & Maintenance  \  Can't peacefully remove the turn signal cover on my Buick
Anyone know how to or where I can find out how to take off the front turn signal Cover so I can replace the bulb?
It's on my 1990 Buick regal. Thanks
posted by  Driver-88
This on a 2001 but it might be the same. There are two vertical white plastic strips behind the main headlight fixture. You have to pull upwards firmly on these--they lock the headlight in place. Once you slide them up you can pull the entire headlight out through the front (carefully, as it's still wired in) and access the turn signal lamp. Pull off the round rubber cover, pull out the socket, and replace the lamp. Then all you have to do is push the socket back into the main housing, put the headlight back in place and slide the plastic tabs back to lock it in.
posted by  GR4VD1GRB1LL
