Electrial problem?
Home  \  Repairs & Maintenance  \  Electrial problem?
My locks lock, but when I pressed the button again, it wouldent unlock...
What would be the problem??
posted by  Mustang90210
does anyone know the problem?
it sounds like the wire in the door from the swtich to the motor is loose look arround the door and betweenthe door and the car where the hinges are and see if there are any loos or cut wires. If you dont see anything, try looking inside the door by removing the interior panel carfuly. there should be a few screws and then som plastic clips around the edges. gently pry then loose and don't force then because they will break and you will need to go to the dealer for replacemments.
posted by  wizzyb82
