Removing interior door panel on 01 vw jetta
Home  \  Repairs & Maintenance  \  Removing interior door panel on 01 vw jetta
I am in the process of replacing my driver side mirror. In order to do this I need to remove the interior driver side door panel. In detail; how do you remove this panel?
Thank you
posted by  jpak
i've done it on an old toyota and an old ford before and it was in the manual how to do it properly. What I did was stick a screwdriver under the panel and pop out the locking pins and then pop out these little holes on the panel and unscrew screws underneath them. If it is the same way on your car just be careful when popping out the locking pins to try and look under the panel first to see where the pins are and put the screwdriver near them because otherwise they might tear out.
posted by  GR4VD1GRB1LL
