Help! I need some supra advice
Home  \  Repairs & Maintenance  \  Help! I need some supra advice
Hello,
I have an 1987 Toyopta Supra Turbo and I had my gas tank repaired and the place that repaired it wired the fuel pump wrong. It blew the EFI fuse. For several reasons I ended up replacing the fuel pump and now the car wont start. I checked the fuel system and pump is working and getting good pressure. I did find out that the 5 & 6 spark plugs are the only ones firing. Did the resistance test from the shop manual and all coils checked out ok. Was thinking it might be the igniter but a tech at a local shop said none of the plugs would be firing if the igniter is bad. I'm kind of stuck. Hope someone out there has some good advice for me.
Thanks!
posted by  supradude
