1995 hyundai accent...wont start
Home  \  Repairs & Maintenance  \  1995 hyundai accent...wont start
i have a 1995 hyundai accent.....everything works and has power....but when you try and start the car ...it just turns....like its not getting a spark...the ignition coil was changed but that didnt help at all...any info would be very appreciated...
Hey thanx for all the help guys...i found the problem...it was a Blown ECU fuse.... :banghead:
posted by  Godknot
Just a few questions ,have you checked the timing belt,run a compression test ,checked for fuel ,check for spark ,start with the timing belt and go from there . good luck Slim
posted by  Slimone
