1988 ford bronco II
Home  \  Repairs & Maintenance  \  1988 ford bronco II
looking for help changed all inline fuel filters truck runs for a little while then shuts off .let set for a while starts again then stalls short time after.is this problem a fuel pump or is there another filter that i am missing? and is fuel filter or fuel pump inside gas tank please help,old time back yard mechanic.
THANKS
posted by  harry
Hi, would say do a fuel pressure test on it , also check your fuel relay ,on most fords its on the left fender well (some are green an black) have seen them to heat up and shut off, when you turn on key it runs the pump for about 3 seconds and then it and the oil pressure switch keeps the fuel pump running , good luck Slim :banghead:
posted by  Slimone
harry, I have an 88 that did the same thing...I finlley traced it to the fule pump realy. the wire's going into the female plug from the wire harness were loose and would'nt push onto the termanls on the relay good and vibrate loose in a few miles to a week later.I used hotglue to put them back in place. It has been 3 years since and stil holding.maybe this will help
wawa
posted by  wawakil
thanks for your help relay was the problem
posted by  harry
thanks for your help it was the relay
posted by  harry
