Problem here
Home  \  Repairs & Maintenance  \  Problem here
Everytime my car goes over a bump or when people get in or out of my car, it usually squeeks severly… its coming from the rear left passenger seat, and when I took a look at it.. I notice that the rear left side is about a centimeter to an inch lower than the rear right.. Any helpful post would be appreciated.. Thank you!
~and can you tell me if its safe to drive and what is the worst thing that can happen while driving.
'02 4door (AM) lancer ES.
posted by  Ki2AY
Probably a broken spring, first guess. Not good, but then, not too expensive to fix. Have your mechanic put it up on a lift.
BTW, It could be unsafe to drive car like this, so drive carefully to get it checked out ASAP.
posted by  gravistar
ok thank you.. do you have an estimate if it is the spring??
my friend said, it could either be the shocks or struts.
posted by  Ki2AY
I had a terrible squeek in the back quarter panel of my Lumina which turns out to be a bad gromet on the rear end. A little bit of wd40 and my squeek was gone until the next rain. Quick and easy.
posted by  olddude
.... :screwy: ......
anyone wanna take another guess?
posted by  Ki2AY
