Clutch problem.....
I have a 92' eagle talon, manual
whenever i go into 2nd gear while driving, it makes this chu noise where it
soudn like someone farted,but after that, its just fine.
however, when im pass 2nd , everythings find, i wonder if 2nd ggear is
jammed or soething.
anyone got an idea?
Does it always do this? At what speed do you shift into 2nd gear?
whenever i shift into 2nd gear , it make that noise, but when im done shifting to 2nd gear, the noise stops, everything else is normal. think maybe something's jammed?
when only shifting to 2nd gear, but when im done shifting to 2nd gear, the noise stops and everything else is the same. maybe somethings jammed, u think?
Alright. But you didn't answer my other question, at what speed do you shift into second gear?
it was around 25.........
:thumbs: try 15 from now on.
cause some of my friends say 20, and let me see if i shfit at 15, wat it do.
So uh, "wat it do"? :banghead:
chu? chooo chooo
Maybe the synchro is worn out or something. My car has trouble shifting into 5th, it makes a short, bad scraping crunch noise...(yeah nice description eh). I think if the synchro is worn it would do that wouldn't it? Correct me if I am wrong...
Can you say bad 2nd gear synchronizer.
Assuming you are smart enought to push the clutch all the way to the
floor.
Life has presented an opportunity.
Learn how to double-clutch.
