Clicking sound when I turn right
And there's a little something I should go ahead and disclose right now...
this problem started shortly after I changed my brake pads :ohcrap: I
don't know, maybe I thought if I ignored it, it would go away.
This sound comes from the front left wheel when I'm making a right turn.
Not a soft turn like when doing a donut, but rather a full hard turn like
after you've come to a complete stop at a stop sign, and turn the steering
wheel completely before a 90 degree right turn.
I recently took advantage of a free Meineke brake inspection, during which
the guy also checked my CV joints. He said all of the above were fine.
Any ideas what could be causing this sound? I haven't really wanted to
just take off the wheel and check randomly because I have no idea what to
look for. Also I had to go to a tire center to get the lug nuts properly
retorqued, so I didn't want to undo this without a specific goal. Anyway.
Please help.
Hi, you can jack up the car ,get front wheels off the ground (both) and start it up and place it in gear so the front wheels spin and get someone to turn right and left to see if you can spot what is clicking ,most of the time its CV's should use safety stands if you have them , good luck Slim
This seems easy enough. Thanks. I'll do it and let you know what I find :thumbs:
Most likely you'll find nothing by following the above instructions.
Without the weight of the vehicle placing a load on the CV's they aren't
doing enough work to make noise... Unless they are so hopelessly worn that
you can hear them from a mile away, but then the entire exercise is
pointless.
Just as a side note JaneiR36, it's good to know you're turning right.
There might be hope for you yet! :thumbs:
what's your suggestion?
My suggestion, as I have suggested perhaps a thousand times on this forum,
is to have a competent technician look at your car if you're unable to
determine what your problem is. I know this may come to a surprise to some
, but... not everything can be explained and taught on this electronic
medium known as the internet. Some things still require not only
understanding facts and theory, something that may be gained here, but also
a good old fashioned dose of hands on experience, on the job training and a
feel for the machine. How do you share those online?
I can identify a worn CV joint at 20 paces, blindfolded. Perhaps the guy
at Meineke can't. Perhaps he looked at the boots and saw them intact and
assumed the inner workings were okay. Perhaps he's as useless as the day
is long and was fired 10 minutes after inspecting your car because he
didn't know how to do inspections properly. Perhaps it's not a CV at all,
although your description sure sounds as though it is. But then I'm not
there to see, hear or feel it so I can't make the final call.
Finally... from reading your many posts asking for help it's apparent
that you're trying to perform your own maintenance and repairs which is a
noble thing. However it also appears that when something may be above your
knowledge or confidence level you always look for the cheapest route out.
I mean come on, you replaced your own brake pads then "took advantage of a
free Meineke brake inspection". You sound to me like what is known in the
industry as a "sumthin fer nothin" kind of customer, always going from shop
to shop looking for the cheapest way to do it and wanting freebies.
There's that word again, cheap. People like that can also be identified
from 20 paces and seldom get a facilities full attention. My suggestion to
you is to find a good local independent shop and use them... every single
time your car needs something. A good shop will bend over backwards to
take care of a loyal customer and will even help you when you're attempting
to do your own thing. That is worth far more than any coupon, freebie or
advice you can get on the internet. Think about it.
Hi, Yes Hobo is right sometimes it does take the weight of the car to make a CV click, depends on just how bad it is , but take a look anyway ,it might be something else. Good luck Slim
Oops, I almost forgot. Vote Republican. :thumbs:
But what's wrong with having mechanic take a look at the brakes just to
make sure I did it right? If something was busted and I was in over my
head, I would have gladly paid the money to have it fixed properly. But he
said I had "great brake pads and shoes. No loose pads..." etc. When he
did the inspection (which took him all of five minutes), he had the car up
in the air and then had me come look at it with him (illuminating the
underside of the vehicle with that flexible light tool thingie). He did
quote some price in the hundreds to diagnose and fix the problem after
which I thanked him and went home.
You're quite right about my being cheap with this car. Like I said in my
intro, this car was bought totaled from an auction lot, fixed by my Mom,
given to my sister, and then passed down to me. So while I'd like to be
responsible and fix every problem properly, I don't want to pump money into
this car that a) I don't have, and b) that's more than what the car is
worth. Given the history of the car, also, I also feel it's a great
opportunity for me to learn my own maintenance. I'm sure as I'm sitting
here that if this car were bought brand new, I wouldn't be so eager to try
my hands at every little thing that went wrong.
All that said, I'll take the wheels off and see what I can hear. THEN I'll
see about giving it to someone to spend a little more time investigating
the problem.
Nothing, but... Just like everything else in life you get what you pay
for. In this case, due to your admittedly own cheapness, you got exactly
what you paid for. Nothing. Here's another newsflash. "Free inspections"
are not provided to help you out, they are to get you into the shop so
you'll spend money.
I'll type more later, right now I'm taking by lovely wife out for our
weekly date. See ya.
I just didn't see myself giving him money for a minor problem when he
hadn't yet told me what was wrong. He did tell me what was wrong with
something else, though. That got ignored altogether... meh.
So I took the wheel off. Like you said, the clicking problem wouldn't
manifest itself without weight on the wheel. However, I did discover a
loose shim on one of the brake pads. I'm guessing that's the offending
part so hopefully some adhesive from the auto store will fix that right up.
Unbeknownst to me, the brake adhesive is never sold separately. They gave
me multiple suggestions at the auto parts store:
a) take off the shim altogether and spray "brake quiet" on the pads
instead
b) Get new brake pads
c) Same as b), only try cashing in on the limited warranty
They say heat has damaged the thing and pulled it apart, and one of them
said he really hates putting those shims on at all. Still, it looks to me
like something you could just gum back together and be done with.
Any ideas anyone? Or any safety reasons why I shouldn't attempt this at
all?
1. Don't worry about the shim, for reasons of safety at least. The shim
is nothing more than a vibration damper. Keep in mind that audible
vibration is noise, that's why they're called anti-squeal shims. That is
why higher dollar pads come pre-shimmed and cheap pads come without them
completely.
2. Where did you buy the pads and what brand are they? Let me know and
I'll be happy to explain to you how to shove them up the store's poopy and
get new ones for free, depending on the retailer and manufacturer.
3. Spray on brake quite is a bandaid on a broken arm, only a temporary fix
at best. I can teach you a cheaper and better way to do the same thing.
You an even do it in designer colors.
The final thing (that I remember) that I wanted to point out to you in my
last post was... We were talking about the value of a free inspection.
Then you came up with a perfect example to prove the point that I was
attempting to make. Someone of unknown qualifications "inspected" your
brakes and missed the loose shim. By your own admission you're not even
close to an expert, and you found it. Maybe you're more quailified to
repair cars than the guy who did the "inspection", or at least more
thorough.
When the tech checked your CV joints, he was looking for cracks and leaks
in the boots that cover them. Usually, the boots leak out the lubricant
and then, eventually, the joints go.
My experience is that CV joints can be noisy for a long time before they
get annoying enough to replace. You might be able to get more life out of
your joints by repacking them, but the cost is about the the same as
replacement, and you have no guarantee of service life. I once repacked a
dry joint on a VW and switched it left to right. I then put over 100K on
it with no problems (everything else on the car broke, however. My last
Golf, period.) But, YMMV.
When you do replace your CV joints, consider replacing the entire axle. It
comes all assembled and is easy to swap out, thus cheaper. No need to
replace both axles at the same time, unless both are giving trouble.
BTW, there is a chance the noise might be a front wheel bearing. Be
careful, they go bad quickly and can leave you stranded. These are usually
easy to diagnose when the car is on a lift.
Good luck
