1996 Blazer strange 4L60E problem??
Home \ Repairs & Maintenance \ 1996 Blazer strange 4L60E problem??
Greetings, My 96 Blazer has a 4L60E that seems to have an odd problem. When I first start the car up it will run fine, after it runs for a few minutes the trans begins to slip in drive and there is no reverse at all. I can turn the key off and start it right back up and it will work fine for a bit then do it again? Could this be a simple electrical fix or is a total rebuild in order?? I've never seen a trans do this before? Please help if you can. Thanks!
