Blower Motor - 86 Buick Electra Park Evenue
1986 Buick Electra Park Avenue (a.k.a. 1986 Buick Electra & Park Avenue)
The heater doesn't blow air. Tested the blower fan at plug for continuity
and it tested good.
Climate control touch panel was tested and working as well.
Haven't checked relays, don't know what to check them for but do have
them.
Can anyone tell me what to check for with the relays? Can anyone tell me
any other place I should be checking if the relays are ok? Any help is
appreciated, thanks.
Checked all fuses and they are good. With blower disconnected it has continuity between positive terminal and chassis ground. Are there any other components linked to the heating system that can go out other than the relays, fuses, & climate control touch center?
Are you working with a wiring diagram?
To test a relay, you can measure the resistance of the coil. ~75 ohms
could be a rough idea of what you might get.
Also measure the voltage at the terminals. You want to check if the coil
is getting energized, but more importantly if the switch in the relay is
getting closed. So measure that last terminal that is finally supposed to
get power when the relay gets energized. (The terminals are usually marked
on the relay). This is, of course, assuming a normally open type relay,
which most I've seen tend to be.
Another thing you could try is just extract a non-essential and identical
relay from another circuit (if you have one) and substitute it and see if
things work.
If I understand your update, you're not getting power to your blower
motor? You should take a peek at the wiring diagrams in your local parts
store. You need to know what comes before the blower motor so you can
check it out.
sorry... continuity to ground at the positive terminal tells us nothing
about a malfunction. If, for instance, the negative terminal is normally
connected to ground, with no current flowing through the motor (ie, w/the
terminal disconnected), BOTH the positive and negative terminals would
obviously be at the same voltage. You need the wiring diagram to determine
if this is a problem at all.
Do you have a multimeter, by the way?
Measure the voltage at the harness leading up to the blower motor (with
blower/fan ON). That's what will tell you if there's power coming in.
Yes, I used a blower motor, we never had power getting to the fan. Turns out instead of a relay (which I had before and it was for the rear defrosters) there was a blower motor control module that went bad. Went down, picked up a new one and its good as new. Got a new blower motor just in case. Thanks for tips though.
Definately sounds like a relay, You will need a book for this one.
You never learn do you? Why the f*ck won't you read and realize the problem has been solved already and everyone is moved on? :banghead: Idiot.
