93 Taurus Drive Belt
Ok Im having trouble getting this belt back on I just replaced the alternator now time to get the drive belt back on the tension pully just comes off does not move side to side like most ive seen so you can get the belt on tension pulley is just bolted on..... the belt is to tight to get over this pulley... is there a way to get it back on :banghead: anyone know anything about putting a new drive belt on a 93 taurus?
When you have done this and in fact there is no tensioner on idler pulley, simply adjust belt with the alternator. Loosen alt a bit to where you can move it with pry-bar or large screwdriver. Install belt, tension with alt adjustment.
