Power steering problem
Home  \  Repairs & Maintenance  \  Power steering problem
I've recently had the bearings fail on the power steering drive pulley for my 89 falcon. I went and purchased this part and fitted it myself, however I was unable to put the belt on tight enough which causes the steering to shudder slightly when turning corners. Is there any particular way the belt should be put on enable it to be tight as possible.
Thanks.
posted by  matt7899
Just put as much tension as possible
posted by  barretire
