Leaks
(93 Isuzu Rodeo, V6, 3.2L, 4wd, 5speed, 141k)
Guys,
I am running into another problem now, I have noticed a small oil leak
develop a few days ago right behind the oil pan. It only seems to leak when
the engine is running so I got under the vehicle and it doesn't seem to be
from the oil pan but from behind a black plate that covers the bottom part
of the transmission. This plate I assume doesnt need a gasket or anything
because there is a small gap there and even a bolt missing on one end.
Anyway, the oil leak is small (droplets will develop slowly) and it is a
clear thin oil - I am not sure if it is engine oil? Well, the oil from the
engine itself is about 2000 miles old so obviously its not going to be from
that and around that whole area it looks pretty clean. Once in a while it
feels harder to get the gears in, especially first when im stopped but I
had the clutch replaced about a year ago.
NOW, I had it checked out, and they told me it "could" be the main bearing
seal, and "possibly" the rear seal, which I very slightly have an idea what
they are talking about but they couldnt seem to give me a straight answer
other than that and 650.00 to do the job. They also said that the oil level
in the tranny is full. After the "diagnosis" I went home and I looked under
it and there was droplets of antifreeze in that same area. It seems like
they may have done something to it cause it wasn't doing that before and
today, the same. So now there is both droplets of antifreeze and oil coming
from behind that plate. Can someone please help?
Could be your rear main
