1991 Ford Tempo(clicks won't start)
2.3 rebuilt starter new cyl., new starter relay, good batt., new battery
terminals Clicks won't start. sometimes the battery post smokes
left it at a store need help please :banghead:
Sometimes the battery post smokes? Hmm. That would scare the shit out of
me. It also makes me think it's loose. But anyway..
Expensive mistake. You know, buying parts hoping one of them will fix your
problem. People could save so much money if they just use proper diagnosis
first. But anyway...
What you should do is disconnect the electrical connections at the starter
and use a multimeter to test function in the off and start positions. You
know, make sure you have power at the right time at the right place. You
will probably find some weird phenomenon there. Back trace with the same
tests towards your battery until you discover the culprit.
:drool: THANX I'll try anything
change the starter relay located by the battery
