1994 Grandam GT
Hello Everyone,
I have a 1994 Grand am that seems to be having a cooling system problem.
When I drive the car, the cooling system will overheat, sending the coolant
back into the surge tank, and out the preasure cap. This only happens for
a few seconds, and then the temperature goes back down to normal, and the
fluid stops coming out. I only have to drive the car a few miles each day,
and this only happens one time each way. Sounds pretty wierd. I had the
car in the shop, but of course the car didn't act up. Go figure :banghead:
I went ahead and had the shop install a new thermostat, but I am thinking I
may be developing a waterpump issue.
What does everyone think
Does the temperature gauge actually show that your engine is overheating? How much so? It's my opinion that you may have a bad rad cap if not.
Yes the guage does show when the engine overheates. Normal running temp on
the guage is between 150 & 220. The critical mass temp on the guage 280.
During short drive, the temp can reach 280, and the coolant is forced back
into the surge tank and out the presure cap. The strange thing then is
that all of a sudden, the temp will drop and the fluid is recirculated.
This can happen several times during a drive of about 5 miles. I did
purchase a new presure cap as I though that might be the problem, but I was
wondering if it might be a waterpump cutting in and out, causing the flux
in temp when it kicks in and circulates the fluid.
Hope this helps.
In that case I wouldn't know.
Thanks Anyway :thumbs:
