Wont Start - 1991 Toyota Celica St.
I am a woman and I do not understand alot abot cars.My car does not
start
unless I give it a boost but I don't understand because my friends tell me
it is the starter because of the clicking sound it does but it will not
start, but when I give a boost it starts if it were the starter it wouldent
start right.
I have had to charge the battery a couple of time but it always drains
out.I know it is not my altenator because I just put in a new one and it
was checked to see if it had a default. Please can someone help me figure
out what this can be . Thank you so much.
Ivelisse
Sounds like the battery to me. Its the Battery, Solinoid, Alternator or
Starter. Probably not the starter for the reason you mentioned. Also a
boost usually won't overcome a bad solinoid. If you say the alternators
has been checked out It must be the battery.
Batterys last anywhere from 2-4 years in most cars. :hi:
My money is on the battery. Have it tested for free at autozone or advance auto parts if possible.
I may be reading it wrong but did she not say that she has changed her battery a few times? surely that many batteries wouldnt be faulty in a row? We have the same car and the same problem, and we have also had to change the battery a few times yet still have the same drain. Perhaps it is a larger fault with the model.
its definetly a battery fault and she said CHARGE not CHANGE. :thumbs:
Well if the battery is good and the alternator is good, something is DRAINING your battery. :doh(:(am I a dumbass or what?) Check for the things that are not obvious.Trunk light or hood light,,, You assume they are OFF,,,,these are things not thought about,,or not much. It's a good (fair) starting point if everything else is OK. Have you had ANY alterations, options added to you car lately????
if your battery is going dead over night, then there is a parasitic load on the battery . meaning something is on even tho the car is off, maybe stereo.or a door switch is FUBAR. if you have a mutimeter than can measure amps then you can test it, or take it to a shop
alright ignore that cuz someone has already explained it :banghead:
But you mentioned about testing with a multimeter, what should be measured
and what readings are to be expected? I know someone that this is
happening to, but she's going around changing stuff and I want no part of
that until I know what is wrong, really. There's also a weird sound that
she thinks is coming from the distributor, but I'm not sure. She's taken
it to people to fix it, they take her money and she gets it back and it's
still there.
Anyway, the battery has drained a few times and she even spent money
replacing it once. Need to know what's causing this.
Sometimes the cigarette lighter is not switched by the ignition. This means that anything plugged into the lighter (radar detector etc) is a constant drain on your battery. I addition if you have had someone put an aftermarket stereo in, the may have inadvertantly attached the switched power to a constant power source. This will also drain your battery.
does ur battery light work? it should turn on when key to on. then turn off after car running. the charging system will not work if that bulb is out on some cars.
Run that by me one more time. I don't think I understood.
every1 is jumping to conclusions that there is a parasitic load thats killing the battery.. she replaced the alternator, but it does not mean that her charging system is ok. cars have a self test with key on engine off, the battery light should be on, and once car is running, the light should go off.
Come on Lectroid! Why don't you read the dates the post are made,,,,Dumbass :banghead:
No big, Lectroid, I'm currently working on solving a similar problem!
If you would believe it, I found what may be the culprit. Totally by
accident, I might add.
We'd taken out the 15 A left headlight fuse to do a test, and almost
immediately, the thing fell.
[Please skip this paragraph if you'd like, it's slightly off topic]. The
next fifteen minutes were spent using various techniques to dig it back
out. BTW, a mechanic that lives in our neighborhood said he left the
business because of bad practices. For instance, if a screw falls while
they're working on your car, they'd charge you for the time it takes to
find it. Well, DUH. That's obviously time they could've spent working on
someone else's car. I thought he was making sense then, but now, I think
if you truly want to avoid such charges, you should probably pay the extra
money for a more highly skilled technician and *hope* he doesn't make a
similar mistake. Finding the screw / nut / fuse does take time and
somebody's gotta pay.
Anyhoos... when we put the screw back in, we noticed the left head light
would arbitrarily come on and stay on. So I went to Advance Auto to copy
the wiring diagram and will hopefully try to trace the short tomorrow (when
it's bright outside again).
The diagram is rather complicated, though, and I only got part of it.
There's a daytime running system that I didn't even copy. And I only got
the headlight part containing the left side. Any hints? Maybe someone
knows what wires typically cause this problem in a '93 Nissan Altima,
automatic shift, 6-cylinders. And as I've also learned Hayne's diagrams
can be pretty vague. For instance, they'll tell you the wire goes to that
junction box, but won't tell you where it is. No wonder it takes
manufacturers a whole manual to publish this information!
I didn't do the alternator part because unlike other cars I've worked on,
the alternator for this vehicle is on a lower portion of the engine. Hard
to reach.
As for the hood light, I used a key to push the mechanical switch in, and
the light went on and off that way. Was this enough? Also, when the
headlamp was misbehaving, the hood light would not come on.
Anyway, here is the wiring diagram I copied:
http://members.aol.com/janeir36/car-forums/lamp.jpg
well, duh. It looks like the "combination switch" may be perpetually stuck on position 1 or 2 instead of "off." I'll have to check that out tomorrow (testing for a short of sorts, hopefully I'll know where the heck the switch is). Please post anything else you think it might be in the mean time.
I don't think you are going to get any lamps to show if you have a voltmeter sitting between the negative post of the battery and the chassis strap.
It can be what everyone says but yes it can be the starter also. I have had it happened to me 3 x when the starter is drawing to much amp then what the battery can give. Sometimes when the starter is going bad it will draw to much amp and you would need a jump to get it started in addition to a well charge battery. You battery might be going dead because the starter is just killing it. It happened to me on a Camry and 2 Mustang 5.0. If everything fails then I would pull the starter out and have it checked
I'm stuck because I have no way of knowing where that switch is. Any
ideas? I even tried to open up the dash board to check the color of the
wires going into all the connectors, but had a really hard time.
As I suspected, the resistance from the non-battery end of the fuse to the
wire going into the LEFT headlamp was 5.5 ohms, when the lamp was supposed
to be off. The one for the right side was an open circuit (as it's
supposed to be). I don't know, it seems wires may be crossed somewhere,
but I'm having a hard time finding where.
if you fiddle with the head light switch, give it the wiggle test, maybe it's the switch.. just a thought
I'm having trouble locating that headlight switch. Have any idea where it might be and/or how I could go about finding it?
hi i have the same problem with myy 1990 celica the battery light flicks on and off mostly on when i am driving it starts every time i have a new battery 3 days old it still does it
You will if there is power flow.
I actually have the same problem. My Toyota Celica only starts when it wants to. i took out the starter and had it checked and it was fine, i also checked the battery and it was still good. i changed the battery posts too. still it only starts when it wants to. im not sure what the problem is.. but It sounds like its the battery. if not the battery then check the battery posts to see if they need to be changed. or check the starter cable. and check where the starter goes into the transmission and make sure theres no curosion inside where it goes into the trans.
