Electrical Problem in my 1996 Escort
i have a 1996 escort and i just replaced the idle air control valve(iac) and the throttle position sensor(tp) because the car idled real high and the diognosis check said it was those sensors after replacing the sensors the car ran for a day but was still idling real high my mechanic said it was electrical know the car wont even start because i keep blowing fuel injection fuses can some one please help me were do i start know?
Well you are blowing fuses for a reason so I think you should start there. If I were you, I'd disconnect every injector wire harness at the injectors and see if you still blow any fuses. If so then you have a pain in the ass. If you don't blow any fuses, hook them back up one by one until you get a blown fuse.
