95' saab 900s shaking at idle
Bought the car for my girlfriend for a month, the problem came with the car
(I had thought it's sign for strong engines :doh: )
The car (as title with 98k milage, engine 2.3l 4 cylinder non-turbo)
constantly shake when I stop at a red light. (I tried changing gear to
Parking it gets better but still a little.) When I changing gear from/to
Rear, it will give a gust of strong shaking then back to normal. Otherwise
the car run fine and strong, pretty smooth on highway or accelerating.
Anybody can give me some idea before I go to mechanics, or even better,
tell me nothing to worry and let it be :laughing:
thanks
Nothing to worry about. Let it be. That's what you wanted to hear, right?
Yeah. :thumbs:
Well, actually, something comes to mind. Motor mounts.
Well, do you think I would have a prayer to find out which engine mount is broken by myself? My DIY level is self changing oil but I'd like to and think I can learn---except for it needs costly special tools.
Unfortunately, one of the characteristics of the first 2-3 years of the 2.3
Liter 4 cylinder version of the "GM" version of the Saab 900S (1994-1996)
is that they all shake at idle. It was a problem when I bought my 900S
from the day it was delivered. I brought it to the dealer numerous times,
and the engineers in Sweden spent lots of time working on it, but they
could not stop the problem. The essential problem is that the engine is
unbalanced. That doesn't mean it is weak or will wear out fast...only that
the designers did not seat it correctly in the engine compartment. All
engines idle more roughly than when they are cruising along on the road.
But, when the mounting is unbalanced, the shaking transmits itself into the
cabin, resulting in entire car feeling as if it is "shaking" at idle. It
is not harmful to the engine, nor is it a sign that the vehicle will break
down. After about 100,000 miles, the front engine mount will need to be
replaced, because the imbalance puts excessive wear on the rubber portion
of the mount. That isn't going to cause the engine to "fall out", so don't
worry. But, when you accelerate, the engine will unnaturally move upwards,
putting extreme stress on the other engine mounts. For this reason, the
front mount will need to be repaired if it has broken. It is a $250 repair
at the mechanic's garage, or a $60 part for you to replace yourself.
There is virtually nothing you can easily do to stop the shaking, or the
cracking of the rubber on this front engine mount, because the problem
arises out of the basic vehicle design. You might be able to reduce it if
you added shock absorbers, at strategic points in the engine, but that
means a total redesign of the car by an amateur. You might also increase
the idle speed, but that will significantly reduce your gas mileage in city
driving. You will be best served by simply accepting the shake as a
characteristic of the vehicle.
or have the reciprocating assembly balanced when you have the engine
rebuilt....
or maybe don't even worry about it since the thread is 8 months old and
he's probably given the damned thing away by now ... :banghead:
GM made those cars horrible. :banghead:
