Lifters on a 95 Grand Cherokee
Hey Fellas,
Here is a quick one. MY 95 Grand cherokee is now 10 years old. She is
still kickin but as of lately she sounds a lil out of shape. I guess i was
windering what minor tune ups i might want to think of for a car that just
hit 104,000 and is now 10
This is the factory recommendation for 102k;
INSPECT
Brake Hoses
Chassis & Body Nuts & Bolts
Cooling System, Hoses & Clamps
Exhaust System
LUBRICATE
Ball Joints
Steering Linkage
4WD
REPLACE
Engine Oil
Engine Oil Filter
ROTATE
Tires
And this is the factory recommendation for 105k;
FLUSH
Cooling System
INSPECT
Brake Hoses
Exhaust System
LUBRICATE
Ball Joints
Steering Linkage
4WD
REPLACE
Engine Oil
Engine Oil Filter
ROTATE
Tires
INSPECT
Air Cleaner Or Element
Replace if necessary.
That is of course assuming you've kept up with everything else. You have
properly maintained your vehicle, haven't you?
You confused me for awhile, I thought you ment valve lifters from the
title. I need a break from this place. :banghead: Anyway...
Inspections to keep it in tip-top shape!
Inspect brakes, rotors and/or drums, change filters, flush cooling system,
inspect hoses (cooling system & vacuum), check for leaks, Clean throttle
body, clean battery posts of corrosion & ensure proper tightness, inspect
tire wear, rotate tires, inspect and repack wheel bearings and grease
seals, check U-joints, lube u-joints, inspect dust boots on steering,
grease ball joints, check differential gear oil lever, color, and
viscosity, check transmission fluid level, color, and viscosity, change
tranny filter, check all lights, headlights, blinkers, tail lights, and
thats all I can think of for now.
EDIT: I feel like an idiot after posting this, thats the type of list to
give someone who hasnt maintained their vehicle pretty much. Have you
maintained your Jeep?
Yes I do maintain her, just didn't know if I should do anything
major........... like swap for a 5.7 L Hemi :drool:
Thanks fellas
Please do!
This is a work of art to my eyes...
http://www.dodgeboy.net/news/57hemi/images/hemi.jpg
