1996 Jeep Grand Cherokee Laredo cylinder misfire?
Home  \  Repairs & Maintenance  \  1996 Jeep Grand Cherokee Laredo cylinder misfire?
For the past couple weeks I have been experiencing a problem with one of my cylinders misfiring. I will be at a stoplight and my Jeep runs choppy. I took it to Autozone and they said that cylinder #4 was misfiring. My boyfriend replaced plugs, wires, distrubuter cap and rotor. Nothing helped. Tried to add a fuel injector cleaner but it did not help. If anyone can provide info it would be helpful. I can not afford to take my car to a mechanic.
Belladonna
posted by  belladonna13
Hm. maybe cylinder #4 is not exactly miss-firing. I think a compression check for cylinder #4 and the rest of the cylinders while you're at it is in order. Report back...
Thank you for the advice. I was wondering how easy is it to do? Can do it if I dont have the correct tool? Was told that I should try to clean the Throttle Body then replace the O2 sensor.
