Brake light not working on one tail lamp
Home  \  Repairs & Maintenance  \  Brake light not working on one tail lamp
I had a brake light go out on my 1999 Pontiac Montana, drivers side. I changed the top bulb, put in a new 3057 bulb and still no brake light. The bulb works when turning on the regular lights. I checked fuses, nothing is blown, the third lamp works as does the brake light on the passenger side.
Is there a brake light switch I can check? :banghead:
posted by  All6ofUs
i believe both brake lights work on same switch and fuse. the only difference is wiring.. if one works and other dont , it should be open(cut) wire.. or bad bulb connector.. get a multimeter and check for volts when some1 steps on brakes.
posted by  thongsai
Try the turn signals, They most often use the brake light. I have seen a turn signal flasher or the turn signal switch cause a brake light problem on just one side.
posted by  ErnieIII
thanks guys - I'll check those things. I've heard the GM tail lamps have a problem with shorts, my only problem is finding a GM dealer in Germany close by! :ohcrap:
posted by  All6ofUs
