1997 dodge neon backup lights
Home  \  Repairs & Maintenance  \  1997 dodge neon backup lights
Hi I have a 1997 dodge neon with a 2.0L DOHC automatic and when I put the car in reverse the backup lights come on and then go off!!! Can anyone help me with this problem ????? Thanks
posted by  LN97dodge
You may want to check the sensor that switches these lights on at the shifter. It may be coroded and shorting out when u have it in reverse move the shifter back n forth to c if they flash off n on.
posted by  path94finder
mine did the same thing and it was the switch under the fuse box under the hood
posted by  AHCDirtyGirl
My lights don't come on at all. I found a FUSE under the fusebox in the engine compartment, but not a switch. I'm going to look for a bad switch near the shift lever. Any idea where it's located?
Chris
posted by  chabig
how's a picture m/t
Thanks for the picture! I thought it looked familiar--after I saw it I found the same pic on page 7A-4 of my Haynes Neon Manual--but I have the automatic transmission, not the manual. According to the electrical diagram I should be looking for a park/neutral position switch. But I can't find that one in the automatic transaxle chapter.
Chris
posted by  chabig
you mean this one 7b-5 #7 this is also the back-up lights for a/t
