2002 Jetta Transmission
Home  \  Repairs & Maintenance  \  2002 Jetta Transmission
I have a 2002 Jetta TDI with a 4-speed xmission. I had to replace one of the fuses in the interior fuse panel and since then when I put the xmission into "D" it starts out in third gear and will not shift up or down. The engine light on the dash also stays on now. Everything was working great until I replaced the fuse. Any ideas on why this happened and how to fix it?
posted by  GreggGarbee
well i would pull the codes.. the new obd2 cars are really picky when a problem occurs.. it is prolly putting u on 3rd so u would be able to drive home. wat fuse did u replace? have u tried removing it? i think it could be a coincidence
posted by  thongsai
