Vibration when Braking(96'Corolla)
Home  \  Repairs & Maintenance  \  Vibration when Braking(96'Corolla)
What might cause this vibration in the front end when braking(felt more at higher speeds)?
posted by  Nicktheguy
warped rotors/ or drums, try braking with just the hand brake, if it doesnt shake then most likely your brake rotors are warped
Definitely sounds like warped rotors to me, if you take it into a shop they should be able to throw them on a lathe and smooth them out for you as long as it isn't too bad.
posted by  Martian
