Daewoo Leganza Starting Problems
Home  \  Repairs & Maintenance  \  Daewoo Leganza Starting Problems
I'm having trouble starting my 99 Leganza with 75K miles on it. I believe it could be a fuel problem, but I'm not sure. It was driving perfectly fine until it got really cold. I drove it to the store and when I came back out, the car would start, but it would die after a few seconds. I threw in some HEET in the fuel tank, but now the car just cranks and doesn't turn over at all. I don't know what else to try. Can somebody help me?
posted by  boronplaya777
i am having the same poblem with my 99 leganza also. if you have found out the problem, please write back, because i cant find out what it is either. the fuel pump is working just not turning on.
posted by  Jackpuddy
My 99 Daewoo Leganza had a bad fuel pump. The fuel pump started to make quite a bit of noise before it quit running. The new pump makes no noise at all.
posted by  Jackpuddy
Mt 99 Daewoo Leganza did have a bad fuel pump. The pump was louder that usual before it went bad. The new pump makes hardly any noise at all.
posted by  Jackpuddy
