Battery Terminals
Home  \  Repairs & Maintenance  \  Battery Terminals
I'm having trouble removing battery terminals. I believe the type of terminal is called single stud?? I'm used to terminals with a screw that you can loosen that allows you to disconnect it from the battery. How do I disconnect these other terminals from the battery?
posted by  Backwards
I will guess your'e refering to top post battery. Just loosen the nut about a 1/4 inch. then take plier or screwdriver to spread the clamp apart. DO THE NEG- TERM 1ST.Don't do a lot of twisting on the clamp if you can't get it loose. Back the nut off a little more and spread.
posted by  lectroid
there is no nut and bolt on this clamp, it's just a completely round clamp.
posted by  Backwards
????????? side or top? Don't have a pic do you? :doh:
posted by  lectroid
they are side mounted, the best picture I could find in all my searching is at:
http://www.electerm.com/battery.html
about a third of the way down on the right hand side, labled "stud type crimp post"
posted by  Backwards
I have never seen those on a car battery and don't have any idea why one would use them! If thats what you have, the only way I see to remove is with a 2 jaw puller. once i got them off I would absof#####lutely replace them.
posted by  lectroid
Let me backup. What do you see in the center of the terminal??
posted by  lectroid
Got it changed ok. Thanks for the help.
:mrgreen:
posted by  Backwards
