P0420 Catalyst System Efficiency Below Threshold (Bank 1)
Hello all,
I have a '95 Eclipse GST with 86k miles and my "check engine" light came on
recently. I took it to my local dealership and got back a OBD code of
P0420 (Catalyst System Efficiency Below Threshold (Bank 1) ). He
recommended replacing the rear O2 sensor --AND-- the converter ($1369).
My questions are: Shouldn't the dealer know if it's just the rear O2 sensor
by doing some diagnostic tests-- thus saving me +$1000 dollars? Or would
he definately know it's the converter, and if so, why is he suggesting
replacing the rear sensor as well? I just want to make sure everything is
on the up and up...
Oh, and also: He asked me if I planned on keeping the car for long, and I
said not if it keeps costing me this much to run it. Then he said I
probably should not get it fixed because it's only going to get worse. You
think he's being sincere, or is this just a way to get me from going
elsewhere to find a cheaper solution?
Thanks!
wow i love guess and check technicians. its either the rear o2 or cat
crapped out.. highly unlikeyly both. but yea replacing both will fix your
problems.
although he should suggest to u to check the cat first. i didnt know cats
were that expensive.
Thanks for your reply.
Yeah, this a-hole dealership has gotten the better of me before, so I'm
much more cautious of their "solutions" now. I only take it to them
because they're the only Mitsu dealer around for miles.
One time, I took in for service for brakes, and they told me the battery
died (without warning)-- wanted to charge me $150 to replace it. I went to
Sears, bought a $59 battery and I replaced the damn thing myself at the
dealer's lot. During another service they said my headlights were
oxidizing and wanted to charge me $540-- PER HEADLIGHT to replace! I
ordered them on the Internet for $169 per headlight. So yeah, I doubt the
cat really costs much to replace.
Ok, enough venting. Time to find an good, honest tech in the area...
You can test an O2 sensor with a propane torch and voltmeter. Pick up the special socket at a parts store or something. How many miles does this thing have?
