Neons..
Home  \  Repairs & Maintenance  \  Neons..
Hi i just got my car yeaserday and got some neons for it..
i want to hook it up where my dome light is..( not to it )
and i have no idea how to do it! :ohcrap: ..and it has this 12v adaptor (cig lighter) and a box thing that lets me control the lights ( color ) and strobes..
i really don't want to have wires hanging down from my neon to the adaptor..looks dumb :laughing: ...if anyone could help me please..thanks
posted by  91ludesr
Can you cut,splice,solder and heat shrink? Fishing will also be required. If not no need to go further.
posted by  lectroid
yea see its weird..
the cig lighter hooks up to a connecter and then the connecter ( the box thing ) hooks up to the neon..
so i dunno how it would work!?
posted by  91ludesr
here is a pic.C:\WINNT\Profiles\42222\Desktop
posted by  91ludesr
The cig lighter is 12V, so if you don't want to use it, cut the wires between the cig adapter and the box. There should be two wires, +ve and earth .... connect the +ve to the battery (via a fuse I'd suggest) and the earth to the chassis somewhere (something metal!!)
If you only want the lights to work when the ignition is on, make sure the battery source you find is an ignition only one (there will be ignition only and permanently on sources at the fuse panel under the drivers dash).
posted by  windsonian
how'd you go with the neons?
