97 chevy lumina v6 engine leak
Home  \  Repairs & Maintenance  \  97 chevy lumina v6 engine leak
the car is overheating and water in oil and right behind to the sid eof the oil stick is leakin any water or antifreeze i put in it... what wrong???? please helpundefinedundefinedundefined
posted by  rhonda81
it might be a hole in the radiator.
posted by  SCMancini83
what series engine 3100 or 3800
posted by  carlos
GM had problems with intake gaskets leaking, just did a job today on a Cutlass Supreme w/3100 series engine. the same problem as yours milkshake syndrome
posted by  carlos
i was told it was a cracked head gasket or something i just bought it 2 days ago and today it overheated and my engine is full of water...
posted by  rhonda81
you can test for this by removing the spark plugs and cranking your engine(remove your fuel pump relay before trying this and disable your ignition system also)if coolant sprays out of any of your spark plug holes then you either have a cracked head or a blown head gasket.
posted by  carlos
how do i go about doing all of this
posted by  rhonda81
removing the spark plugs from the rear can get quite difficult find someone who can help you and offer them a few bucks to do this test, you can save yourself a lot of money if you see the results yourself, instead of having someone lie to you and ripping you off
posted by  carlos
whats messed up on it...Thanks
posted by  rhonda81
if coolant doesn't come out the spark plug holes don't let them tell you it's a head gasket(usually a $600 job at a shop) chances are it's your intake gaskets, GM even had a recall on them
posted by  carlos
the hole is usually in the radiator hose and under pressure it grows all you have to do is replace it.[/FONT][/SIZE][/COLOR]
posted by  tapraehs
check the radiator hose they have quite weak hoses installled in the stock engines. :thumbs:
posted by  tapraehs
